LTIMindtree
Last activity: 4 Jun 2021 0:16 EDT
Rule resolution is picking up a different rule
Description: Application ABC is built on XYZ. There is section named SEC in both the Classes like, XYZ- FW-CFW-work SEC and ABC- DIV- Unit- work SEC. This SEC is getting called from a section named PEGASEC which is in PegaCA-work class.
Issue: SEC is picking up from XYZ-FW-CFW-work class where it suppose to pick from ABC- DIV- Unit- work.
Is that correct? If I'm not wrong.
If you are willing to answer, please post here.
Thanks in advance.
