RPA Perform Click resulting in message box (issue)
I have a perform click in my automation, which when fired, it does perform the click but, it then gets stuck. When using the breakpoint, I can see it never highlights the Perform Click step. However, as soon as I close the message window I can see from the breakpoint that it then highlights the perform click as completed.
The problem is that I need to click OK on that message box to continue my process.
I have been unable to find a way around this issue, see attached pictures to try and explain further.
Edit: If i replace the click with pure JS this again fires fine, but when the message box appears the automation freezes.
