RPA - Lookup Table AutoIncrement Index Exception
This is my first attempt with replacetable autokey methods, so I may be doing this incorrectly.
The actual solution uses a similar approach with jsonutils to serialize data for a temp cache. I ran into an exception after invoking GetTableWithoutKey() then trying to add a new record to the same table.
I built a small test code that fails in Pega Robotics Studio 19.1.77:
The error found in the logs is:
INFO | 2021-07-15 13:54:59,848 | 16 | 16 | 14984 | MTA | Automation | Automation1 | luErrors-8281398 | AddRecord: Exception invoking method - Column 'ID' is constrained to be unique. Value '1' is already present.
Is this error expected with this automation?
Am I using this incorrectly? / Is this a design issue?
The simple fix is handling the index manually, removing the index conflict, but I'd like to avoid this unless necessary.
Thanks!
-Chris
