Restricting access based on specific ruleset - Impacts on functionalities at Runtime
When developer added or removed the Ruleset restrictions in class - Advanced Tab, whether this changes will have any impact on the functionalities at the runtime (i.e. when Ruleset is available in Rule stack).
Example:
1. RulesetA & RulesetB are available in the Application Ruleset of Application rule
1. Developer - Added the RulesetA & RulesetB in Ruleset restrictions of Class_A in Advanced Tab.
2. Performed the changes in using the RulesetA:XX-XX-XX.
3. Removed the RulesetA in Ruleset restrictions of Class_A. (Observation - Developer will not be able to pick the RulesetA:XX-XX-XX using the class_A while saving the rules and will be able to select the RulesetB:XX-XX-XX using the Class_A while saving the rules)
Do users have any impact on the functionalities due to this changes at runtime?
Especially when the code is moved into the higher environments or there is no dependencies with this changes at the runtime.
Any suggestions?
Regards
SVAQuest
