REST connector - calling method 'OPTIONS'
Need a way to configure a REST connector to call the method 'OPTIONS'.
Any suggestions please?
Please go through below article for the detailed explanation how to consume a rest service from Pega .
https://www.pegaxchange.com/2016/10/16/pega-7-connect-rest/
Arun
Hi Arun,
Thank you for your reply.
But here I need to call the "OPTIONS" method which is not given in the connector rules Methods tab. Will there be any OOTB way or a workaround to achieve this.
Dewdun
Hi Dewdun,
I don't think you can achieve that currently in Pega using Rest Wizard.
Only 4 methods are currently supported. May be this can be taken as enhancement.
Others can comment :)
Thank you
-Abhishek
