Report Definition running slow on 1st Run. But works fine during second run
Hi Team,
Can you please suggest about the reason why the report definition is running slow during 1st run. But the same is running fine in 2nd run. Also, when I have investigated I found out that getcontent activity is taking maximum time in both the runs. For example in 1st run it took 24 seconds and in second run it took 0.7 seconds. I am not sure where to tuneup as there is vast difference between both the runs.
Please let me know if you need more inputs.
Hemant
