EY
HK
Last activity: 4 Oct 2021 6:28 EDT
'Ready to Process' Queue Processor
I have a queue processor and I can see in Admin Studio a lot of entries are stuck in the "Ready to Process" state. How do I check these entries and debug why these are stuck in "Ready to Process" state?
You will be able to identify denfinite errors in the pega rules /Catalina logs. Make sure pyBatchIndexClassesProcessor is running as it may cause issue with other agents
Hi Geetansh
You can click on the entries those are stuck and see the View XML to get more details .
You can also enable these debuggers and set them to debug to get more information in logs :
com.pega.pegarules.session.internal.async.BatchRequestorTask
com.pega.pegarules.session.internal.async.agent.QueueManagerImpl
com.pega.pegarules.session.internal.async.agent.QueueProcessor
EY
HK
The entries in "Ready to Process" are not clickable in Admin Studio. There is no option to View XML for "Ready to Process" Its available for "Scheduled" or "Broken" state.
Hi Geetansh
you can enable the above mentioned debuggers and check the logs entries .
Talk Talk
Hi, we are facing the same issue where we have entries stuck in the "Ready to Process" state. I have enabled the debuggers mentioned above and included logs for when the Queue Processor attempts to process those entries. I can see the logs that say 'No item to process' and 'No records found matching selection criteria', could this be what the issue is?
020-08-20 11:10:28,269 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-ImportExport #1: System-Queue-PostImport-ColPop.pzProcessPostImportQueueItem 2020-08-20 11:10:28,269 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-PostImport-ColPop.pzProcessPostImportQueueItem; ending run. 2020-08-20 11:10:28,307 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:SendCorr 2020-08-20 11:10:28,309 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:FTSIncrementalIndexer 2020-08-20 11:10:28,309 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "Data-Corr-.Send" executing for Agent : "SendCorr" 2020-08-20 11:10:28,310 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,310 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,310 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,312 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-FTSIncrementalIndexer.pzFTSIncrementalIndexer" executing for Agent : "FTSIncrementalIndexer" 2020-08-20 11:10:28,312 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - Batch activity ready to execute: System-Queue-FTSIncrementalIndexer.pzFTSIncrementalIndexer 2020-08-20 11:10:28,312 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - Using rulesets: [Pega-ProcessCommander:08-03|Pega-DeploymentDefaults:08-03|Pega-DecisionScience:08-03|Pega-DecisionArchitect:08-03|Pega-LP-Mobile:08-03|Pega-LP-ProcessAndRules:08-03|Pega-LP-Integration:08-03|Pega-LP-Reports:08-03|Pega-LP-SystemSettings:08-03|Pega-LP-UserInterface:08-03|Pega-LP-OrgAndSecurity:08-03|Pega-LP-DataModel:08-03|Pega-LP-Application:08-03|Pega-LP:08-03|Pega-SystemOperations:08-03|Pega-UpdateManager:08-03|Pega-SecurityVA:08-03|Pega-Feedback:08-03|Pega-HealthCheck:08-03|Pega-AutoTest:08-03|Pega-AppDefinition:08-03|Pega-ImportExport:08-03|Pega-LocalizationTools:08-03|Pega-RuleRefactoring:08-03|Pega-ProcessArchitect:08-03|Pega-Portlet:08-03|Pega-Content:08-03|Pega-BigData:08-03|Pega-NLP:08-03|Pega-DecisionEngine:08-03|Pega-IntegrationArchitect:08-03|Pega-SystemArchitect:08-03|Pega-Desktop:08-03|Pega-EndUserUI:08-03|Pega-Survey:08-03|Pega-Social:08-03|Pega-SharedData:08-03|Pega-API:08-03|Pega-EventProcessing:08-03|Pega-Reporting:08-03|Pega-UIDesign:08-03|Pega-Gadgets:08-03|Pega-UIEngine:08-03|Pega-ProcessEngine:08-03|Pega-SearchEngine:08-03|Pega-IntegrationEngine:08-03|Pega-RulesEngine:08-03|Pega-Engine:08-03|PegaLegacyRules:01-01|Pega-ProCom:08-03|Pega-IntSvcs:08-03|Pega-WB:08-03|Pega-RULES:08-03|] 2020-08-20 11:10:28,312 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = false, useCursor = false) 2020-08-20 11:10:28,312 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,312 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,313 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-DefaultEntry</pxObjClass> <pxLastExecutionDateTime>20200820T101028.310 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-ProCom:SendCorr</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queues</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,313 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-ProCom #2: Data-Corr-.Send 2020-08-20 11:10:28,313 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): Data-Corr-.Send; ending run. 2020-08-20 11:10:28,315 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-FTSIncrementalIndexer</pxObjClass> <pxLastExecutionDateTime>20200820T101028.312 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-SearchEngine:FTSIncrementalIndexer</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queue_ftsindexer</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,315 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-FTSIncrementalIndexer.pzFTSIncrementalIndexer; ending run. 2020-08-20 11:10:28,330 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:Post-Import Indexing 2020-08-20 11:10:28,332 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-PostImport-RDI.pzProcessPostImportQueueItem" executing for Agent : "Post-Import Indexing" 2020-08-20 11:10:28,333 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,333 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,333 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,336 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-PostImport-RDI</pxObjClass> <pxLastExecutionDateTime>20200820T101028.333 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-ImportExport:Post-Import Indexing</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queues</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,336 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-ImportExport #2: System-Queue-PostImport-RDI.pzProcessPostImportQueueItem 2020-08-20 11:10:28,336 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-PostImport-RDI.pzProcessPostImportQueueItem; ending run. 2020-08-20 11:10:28,341 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:Post-Import Migration 2020-08-20 11:10:28,343 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-PostImport-Migration.pzRunMigration" executing for Agent : "Post-Import Migration" 2020-08-20 11:10:28,344 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,344 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,344 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,344 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:GenerateStartingFlows 2020-08-20 11:10:28,345 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:AgentCaseBulkProcessing 2020-08-20 11:10:28,346 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-StartingFlows.GenerateStartingFlows" executing for Agent : "GenerateStartingFlows" 2020-08-20 11:10:28,346 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,347 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,347 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,347 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-BulkCaseProcess.pzBulkProcessCases" executing for Agent : "AgentCaseBulkProcessing" 2020-08-20 11:10:28,347 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,348 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,348 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,348 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-PostImport-Migration</pxObjClass> <pxLastExecutionDateTime>20200820T101028.344 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-ImportExport:Post-Import Migration</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queues</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,348 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-ImportExport #5: System-Queue-PostImport-Migration.pzRunMigration 2020-08-20 11:10:28,348 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-PostImport-Migration.pzRunMigration; ending run. 2020-08-20 11:10:28,349 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:FTSConflictsHandler 2020-08-20 11:10:28,350 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-StartingFlows</pxObjClass> <pxLastExecutionDateTime>20200820T101028.346 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-ProCom:GenerateStartingFlows</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queue_startflows</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,350 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-ProCom #3: System-Queue-StartingFlows.GenerateStartingFlows 2020-08-20 11:10:28,350 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-FTSConflictsHandler.pzFTSConflictsHandler" executing for Agent : "FTSConflictsHandler" 2020-08-20 11:10:28,350 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-StartingFlows.GenerateStartingFlows; ending run. 2020-08-20 11:10:28,351 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-BulkCaseProcess</pxObjClass> <pxLastExecutionDateTime>20200820T101028.347 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-ProcessEngine:AgentCaseBulkProcessing</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queues</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,351 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-ProcessEngine #0: System-Queue-BulkCaseProcess.pzBulkProcessCases 2020-08-20 11:10:28,351 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-BulkCaseProcess.pzBulkProcessCases; ending run. 2020-08-20 11:10:28,351 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - Batch activity ready to execute: System-Queue-FTSConflictsHandler.pzFTSConflictsHandler 2020-08-20 11:10:28,351 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - Using rulesets: [Pega-ProcessCommander:08-03|Pega-DeploymentDefaults:08-03|Pega-DecisionScience:08-03|Pega-DecisionArchitect:08-03|Pega-LP-Mobile:08-03|Pega-LP-ProcessAndRules:08-03|Pega-LP-Integration:08-03|Pega-LP-Reports:08-03|Pega-LP-SystemSettings:08-03|Pega-LP-UserInterface:08-03|Pega-LP-OrgAndSecurity:08-03|Pega-LP-DataModel:08-03|Pega-LP-Application:08-03|Pega-LP:08-03|Pega-SystemOperations:08-03|Pega-UpdateManager:08-03|Pega-SecurityVA:08-03|Pega-Feedback:08-03|Pega-HealthCheck:08-03|Pega-AutoTest:08-03|Pega-AppDefinition:08-03|Pega-ImportExport:08-03|Pega-LocalizationTools:08-03|Pega-RuleRefactoring:08-03|Pega-ProcessArchitect:08-03|Pega-Portlet:08-03|Pega-Content:08-03|Pega-BigData:08-03|Pega-NLP:08-03|Pega-DecisionEngine:08-03|Pega-IntegrationArchitect:08-03|Pega-SystemArchitect:08-03|Pega-Desktop:08-03|Pega-EndUserUI:08-03|Pega-Survey:08-03|Pega-Social:08-03|Pega-SharedData:08-03|Pega-API:08-03|Pega-EventProcessing:08-03|Pega-Reporting:08-03|Pega-UIDesign:08-03|Pega-Gadgets:08-03|Pega-UIEngine:08-03|Pega-ProcessEngine:08-03|Pega-SearchEngine:08-03|Pega-IntegrationEngine:08-03|Pega-RulesEngine:08-03|Pega-Engine:08-03|PegaLegacyRules:01-01|Pega-ProCom:08-03|Pega-IntSvcs:08-03|Pega-WB:08-03|Pega-RULES:08-03|] 2020-08-20 11:10:28,351 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = false, useCursor = false) 2020-08-20 11:10:28,351 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,351 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,353 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-FTSConflictsHandler</pxObjClass> <pxLastExecutionDateTime>20200820T101028.351 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-SearchEngine:FTSConflictsHandler</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queue_ftsconflict</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,354 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-FTSConflictsHandler.pzFTSConflictsHandler; ending run. 2020-08-20 11:10:28,354 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:Post-Import UAS 2020-08-20 11:10:28,356 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-PostImport-UpgradeApplicationsSchema.pzRunUASForQueueItem" executing for Agent : "Post-Import UAS" 2020-08-20 11:10:28,356 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,356 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,357 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,359 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-PostImport-UpgradeApplicationsSchema</pxObjClass> <pxLastExecutionDateTime>20200820T101028.356 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-ImportExport:Post-Import UAS</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queues</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,359 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-ImportExport #4: System-Queue-PostImport-UpgradeApplicationsSchema.pzRunUASForQueueItem 2020-08-20 11:10:28,359 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-PostImport-UpgradeApplicationsSchema.pzRunUASForQueueItem; ending run. 2020-08-20 11:10:28,397 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:SystemEventEvaluation 2020-08-20 11:10:28,398 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-Events.pzSystemEventEvaluation" executing for Agent : "SystemEventEvaluation" 2020-08-20 11:10:28,401 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - Batch activity ready to execute: System-Queue-Events.pzSystemEventEvaluation 2020-08-20 11:10:28,401 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - Using rulesets: [EventProcessing-Internal:01-01|Pega-ProcessCommander:08-03|Pega-DeploymentDefaults:08-03|Pega-DecisionScience:08-03|Pega-DecisionArchitect:08-03|Pega-LP-Mobile:08-03|Pega-LP-ProcessAndRules:08-03|Pega-LP-Integration:08-03|Pega-LP-Reports:08-03|Pega-LP-SystemSettings:08-03|Pega-LP-UserInterface:08-03|Pega-LP-OrgAndSecurity:08-03|Pega-LP-DataModel:08-03|Pega-LP-Application:08-03|Pega-LP:08-03|Pega-SystemOperations:08-03|Pega-UpdateManager:08-03|Pega-SecurityVA:08-03|Pega-Feedback:08-03|Pega-HealthCheck:08-03|Pega-AutoTest:08-03|Pega-AppDefinition:08-03|Pega-ImportExport:08-03|Pega-LocalizationTools:08-03|Pega-RuleRefactoring:08-03|Pega-ProcessArchitect:08-03|Pega-Portlet:08-03|Pega-Content:08-03|Pega-BigData:08-03|Pega-NLP:08-03|Pega-DecisionEngine:08-03|Pega-IntegrationArchitect:08-03|Pega-SystemArchitect:08-03|Pega-Desktop:08-03|Pega-EndUserUI:08-03|Pega-Survey:08-03|Pega-Social:08-03|Pega-SharedData:08-03|Pega-API:08-03|Pega-EventProcessing:08-03|Pega-Reporting:08-03|Pega-UIDesign:08-03|Pega-Gadgets:08-03|Pega-UIEngine:08-03|Pega-ProcessEngine:08-03|Pega-SearchEngine:08-03|Pega-IntegrationEngine:08-03|Pega-RulesEngine:08-03|Pega-Engine:08-03|PegaLegacyRules:01-01|Pega-ProCom:08-03|Pega-IntSvcs:08-03|Pega-WB:08-03|Pega-RULES:08-03|] 2020-08-20 11:10:28,401 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = false) 2020-08-20 11:10:28,401 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,401 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,403 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-Events</pxObjClass> <pxLastExecutionDateTime>20200820T101028.401 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_cep_events_queue</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,403 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-Events.pzSystemEventEvaluation; ending run. 2020-08-20 11:10:28,555 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:AgentBulkProcessing 2020-08-20 11:10:28,556 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:ServiceLevelEvents 2020-08-20 11:10:28,557 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-ServiceLevel.ProcessEvent" executing for Agent : "ServiceLevelEvents" 2020-08-20 11:10:28,557 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-BulkProcess.pzAgentBulkProcessing" executing for Agent : "AgentBulkProcessing" 2020-08-20 11:10:28,558 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,558 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,558 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,558 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,558 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,558 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,559 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:Refactor Copy/Move/Merge 2020-08-20 11:10:28,560 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "PegaAccel-Management-Refactor-RuleSet.ProcessRequest" executing for Agent : "Refactor Copy/Move/Merge" 2020-08-20 11:10:28,560 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,560 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,560 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,561 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-BulkProcess</pxObjClass> <pxLastExecutionDateTime>20200820T101028.558 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-ProCom:AgentBulkProcessing</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queues</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,561 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-ProCom #1: System-Queue-BulkProcess.pzAgentBulkProcessing 2020-08-20 11:10:28,561 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-BulkProcess.pzAgentBulkProcessing; ending run. 2020-08-20 11:10:28,561 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-ServiceLevel</pxObjClass> <pxLastExecutionDateTime>20200820T101028.558 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-ProCom:ServiceLevelEvents</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queue_sla</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,561 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-ProCom #0: System-Queue-ServiceLevel.ProcessEvent 2020-08-20 11:10:28,561 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-ServiceLevel.ProcessEvent; ending run. 2020-08-20 11:10:28,563 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-DefaultEntry</pxObjClass> <pxLastExecutionDateTime>20200820T101028.560 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-RuleRefactoring:Refactor Copy/Move/Merge</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queues</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,563 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-RuleRefactoring #0: PegaAccel-Management-Refactor-RuleSet.ProcessRequest 2020-08-20 11:10:28,563 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): PegaAccel-Management-Refactor-RuleSet.ProcessRequest; ending run. 2020-08-20 11:10:28,564 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:ProcessFlowDependencies 2020-08-20 11:10:28,566 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-FlowDependency.pzProcessFlowDependency" executing for Agent : "ProcessFlowDependencies" 2020-08-20 11:10:28,566 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,566 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,566 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,568 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-FlowDependency</pxObjClass> <pxLastExecutionDateTime>20200820T101028.566 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-ProcessEngine:ProcessFlowDependencies</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queues</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,568 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-ProcessEngine #2: System-Queue-FlowDependency.pzProcessFlowDependency 2020-08-20 11:10:28,568 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-FlowDependency.pzProcessFlowDependency; ending run. 2020-08-20 11:10:28,590 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:ProcessNotification 2020-08-20 11:10:28,590 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:SystemPulse 2020-08-20 11:10:28,592 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "Code-.SystemPulse" executing for Agent : "SystemPulse" 2020-08-20 11:10:28,593 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - Batch activity ready to execute: Code-.SystemPulse 2020-08-20 11:10:28,593 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - Using rulesets: [Pega-ProcessCommander:08-03|Pega-DeploymentDefaults:08-03|Pega-DecisionScience:08-03|Pega-DecisionArchitect:08-03|Pega-LP-Mobile:08-03|Pega-LP-ProcessAndRules:08-03|Pega-LP-Integration:08-03|Pega-LP-Reports:08-03|Pega-LP-SystemSettings:08-03|Pega-LP-UserInterface:08-03|Pega-LP-OrgAndSecurity:08-03|Pega-LP-DataModel:08-03|Pega-LP-Application:08-03|Pega-LP:08-03|Pega-SystemOperations:08-03|Pega-UpdateManager:08-03|Pega-SecurityVA:08-03|Pega-Feedback:08-03|Pega-HealthCheck:08-03|Pega-AutoTest:08-03|Pega-AppDefinition:08-03|Pega-ImportExport:08-03|Pega-LocalizationTools:08-03|Pega-RuleRefactoring:08-03|Pega-ProcessArchitect:08-03|Pega-Portlet:08-03|Pega-Content:08-03|Pega-BigData:08-03|Pega-NLP:08-03|Pega-DecisionEngine:08-03|Pega-IntegrationArchitect:08-03|Pega-SystemArchitect:08-03|Pega-Desktop:08-03|Pega-EndUserUI:08-03|Pega-Survey:08-03|Pega-Social:08-03|Pega-SharedData:08-03|Pega-API:08-03|Pega-EventProcessing:08-03|Pega-Reporting:08-03|Pega-UIDesign:08-03|Pega-Gadgets:08-03|Pega-UIEngine:08-03|Pega-ProcessEngine:08-03|Pega-SearchEngine:08-03|Pega-IntegrationEngine:08-03|Pega-RulesEngine:08-03|Pega-Engine:08-03|PegaLegacyRules:01-01|Pega-ProCom:08-03|Pega-IntSvcs:08-03|Pega-WB:08-03|Pega-RULES:08-03|] 2020-08-20 11:10:28,593 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-Notification.pzProcessNotification" executing for Agent : "ProcessNotification" 2020-08-20 11:10:28,594 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,594 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,594 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,595 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:RevalidateAndSave 2020-08-20 11:10:28,596 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-Notification</pxObjClass> <pxLastExecutionDateTime>20200820T101028.594 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-ProcessEngine:ProcessNotification</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queues</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,596 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-ProcessEngine #3: System-Queue-Notification.pzProcessNotification 2020-08-20 11:10:28,597 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-Notification.pzProcessNotification; ending run. 2020-08-20 11:10:28,597 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): Code-.SystemPulse; ending run. 2020-08-20 11:10:28,597 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-RevalidateAndSave.pzPerformRevalidateAndSave" executing for Agent : "RevalidateAndSave" 2020-08-20 11:10:28,598 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,598 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,598 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,598 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:UpdateActiveNonQuiesceAdminRequestors 2020-08-20 11:10:28,600 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Status-Nodes.pyUpdateActiveUserCount" executing for Agent : "UpdateActiveNonQuiesceAdminRequestors" 2020-08-20 11:10:28,600 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-RevalidateAndSave</pxObjClass> <pxLastExecutionDateTime>20200820T101028.598 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-ImportExport:RevalidateAndSave</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queues</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,600 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-ImportExport #3: System-Queue-RevalidateAndSave.pzPerformRevalidateAndSave 2020-08-20 11:10:28,600 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-RevalidateAndSave.pzPerformRevalidateAndSave; ending run. 2020-08-20 11:10:28,600 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - Batch activity ready to execute: System-Status-Nodes.pyUpdateActiveUserCount 2020-08-20 11:10:28,600 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - Using rulesets: [Pega-ProcessCommander:08-03|Pega-DeploymentDefaults:08-03|Pega-DecisionScience:08-03|Pega-DecisionArchitect:08-03|Pega-LP-Mobile:08-03|Pega-LP-ProcessAndRules:08-03|Pega-LP-Integration:08-03|Pega-LP-Reports:08-03|Pega-LP-SystemSettings:08-03|Pega-LP-UserInterface:08-03|Pega-LP-OrgAndSecurity:08-03|Pega-LP-DataModel:08-03|Pega-LP-Application:08-03|Pega-LP:08-03|Pega-SystemOperations:08-03|Pega-UpdateManager:08-03|Pega-SecurityVA:08-03|Pega-Feedback:08-03|Pega-HealthCheck:08-03|Pega-AutoTest:08-03|Pega-AppDefinition:08-03|Pega-ImportExport:08-03|Pega-LocalizationTools:08-03|Pega-RuleRefactoring:08-03|Pega-ProcessArchitect:08-03|Pega-Portlet:08-03|Pega-Content:08-03|Pega-BigData:08-03|Pega-NLP:08-03|Pega-DecisionEngine:08-03|Pega-IntegrationArchitect:08-03|Pega-SystemArchitect:08-03|Pega-Desktop:08-03|Pega-EndUserUI:08-03|Pega-Survey:08-03|Pega-Social:08-03|Pega-SharedData:08-03|Pega-API:08-03|Pega-EventProcessing:08-03|Pega-Reporting:08-03|Pega-UIDesign:08-03|Pega-Gadgets:08-03|Pega-UIEngine:08-03|Pega-ProcessEngine:08-03|Pega-SearchEngine:08-03|Pega-IntegrationEngine:08-03|Pega-RulesEngine:08-03|Pega-Engine:08-03|PegaLegacyRules:01-01|Pega-ProCom:08-03|Pega-IntSvcs:08-03|Pega-WB:08-03|Pega-RULES:08-03|] 2020-08-20 11:10:28,600 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:ProcessConnectQueue 2020-08-20 11:10:28,602 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-ExecutionRequest-Connect-Default.ProcessQueue" executing for Agent : "ProcessConnectQueue" 2020-08-20 11:10:28,602 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - Batch activity ready to execute: System-Queue-ExecutionRequest-Connect-Default.ProcessQueue 2020-08-20 11:10:28,602 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - Using rulesets: [Pega-ProcessCommander:08-03|Pega-DeploymentDefaults:08-03|Pega-DecisionScience:08-03|Pega-DecisionArchitect:08-03|Pega-LP-Mobile:08-03|Pega-LP-ProcessAndRules:08-03|Pega-LP-Integration:08-03|Pega-LP-Reports:08-03|Pega-LP-SystemSettings:08-03|Pega-LP-UserInterface:08-03|Pega-LP-OrgAndSecurity:08-03|Pega-LP-DataModel:08-03|Pega-LP-Application:08-03|Pega-LP:08-03|Pega-SystemOperations:08-03|Pega-UpdateManager:08-03|Pega-SecurityVA:08-03|Pega-Feedback:08-03|Pega-HealthCheck:08-03|Pega-AutoTest:08-03|Pega-AppDefinition:08-03|Pega-ImportExport:08-03|Pega-LocalizationTools:08-03|Pega-RuleRefactoring:08-03|Pega-ProcessArchitect:08-03|Pega-Portlet:08-03|Pega-Content:08-03|Pega-BigData:08-03|Pega-NLP:08-03|Pega-DecisionEngine:08-03|Pega-IntegrationArchitect:08-03|Pega-SystemArchitect:08-03|Pega-Desktop:08-03|Pega-EndUserUI:08-03|Pega-Survey:08-03|Pega-Social:08-03|Pega-SharedData:08-03|Pega-API:08-03|Pega-EventProcessing:08-03|Pega-Reporting:08-03|Pega-UIDesign:08-03|Pega-Gadgets:08-03|Pega-UIEngine:08-03|Pega-ProcessEngine:08-03|Pega-SearchEngine:08-03|Pega-IntegrationEngine:08-03|Pega-RulesEngine:08-03|Pega-Engine:08-03|PegaLegacyRules:01-01|Pega-ProCom:08-03|Pega-IntSvcs:08-03|Pega-WB:08-03|Pega-RULES:08-03|] 2020-08-20 11:10:28,603 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = false) 2020-08-20 11:10:28,603 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,603 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,603 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Status-Nodes.pyUpdateActiveUserCount; ending run. 2020-08-20 11:10:28,605 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-ExecutionRequest-Connect-Default</pxObjClass> <pxLastExecutionDateTime>20200820T101028.603 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queue_execreq_conn</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,605 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): System-Queue-ExecutionRequest-Connect-Default.ProcessQueue; ending run. 2020-08-20 11:10:28,611 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:pzProcessRebase 2020-08-20 11:10:28,613 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "PegaAccel-Management-Rebase.pzProcessRebase" executing for Agent : "pzProcessRebase" 2020-08-20 11:10:28,613 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,613 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,613 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,615 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?> <pagedata> <pxObjClass>System-Queue-DefaultEntry</pxObjClass> <pxLastExecutionDateTime>20200820T101028.613 GMT</pxLastExecutionDateTime> <pxProcessingNodeId>eb99f3697500cfc2fcd29e6da927a340</pxProcessingNodeId> <pzTrue>true</pzTrue> <pyAgentName>Pega-RuleRefactoring:pzProcessRebase</pyAgentName> <pzFalse>false</pzFalse> <pyItemStatus>Scheduled</pyItemStatus> <pyTableName>PegaDATA.pr_sys_queues</pyTableName> <pzStatus>valid</pzStatus> </pagedata> 2020-08-20 11:10:28,615 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueProcessor) DEBUG - No item to process: Pega-RuleRefactoring #1: PegaAccel-Management-Rebase.pzProcessRebase 2020-08-20 11:10:28,616 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - run(): PegaAccel-Management-Rebase.pzProcessRebase; ending run. 2020-08-20 11:10:28,749 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Starting task for Agent:StartSimulationRun 2020-08-20 11:10:28,751 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] (ernal.async.BatchRequestorTask) DEBUG - Batch activity "System-Queue-Simulation.pzScheduledSimulationRun" executing for Agent : "StartSimulationRun" 2020-08-20 11:10:28,753 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Checking for next item (lock = true, useCursor = true) 2020-08-20 11:10:28,753 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Selecting oldest item. 2020-08-20 11:10:28,753 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - next(): Attempting to lock item for processing 2020-08-20 11:10:28,756 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ PegaRULES:8] ( async.agent.QueueManagerImpl) DEBUG - No records found matching selection criteria: <?xml version="1.0"?>
Tech Mahindra
What is the resolution for this one.
Standard Chartered Bank
For me, when I click open the three dotted icon, view data flow, it was in paused state, resuming it moved the items into processing
