Tata Consultancy Services Limited
Last activity: 30 Oct 2015 5:51 EDT
Radio button values are not shown in single line.
I have a radio button configured as local list of 6 values. but in UI, only 3 values are shown in a single line and the remaining 3 are shown in the next line. Is it possible to show all 6 values of a radio button in a single line?
could you please try changing dynamic layout / container formats...(inline, etc...)
Dear Phani,
Thanks for your reply
I have tried all combinations, still no success. I am using pega 7.1.7.
I have raised SR for this issue.
Could you reply with the SR you created for this please? You can also add it to the Related Work section within your original reply.
Thanks in advance!
Dear Marrissa Rogers,
But I got an email saying that it falls outside the scope of work supported by GCS
I raised under "How-To question" request type. If i put Problem as request type then it is asking me to upload previous hot fix files which is not applicable for my issue.
Thanks Guhanathan Vijayanarayanan
Let's just keep the post open in here and see if Phani can help you or another PSC member!
Thanks for the advice
could you please try specifying '10' as value instead of blank for items before new row field...
Genius working fine...
not only for 10 it is also working for 11, 12 ...
Do you know the logic behind it ?
Thanks a lot for your help...
Updated: 29 Oct 2015 13:53 EDT
assuming the code behind the UI generation might have been implemented to consider optimal value (3) if the field is blank.
it should work for any value above 6 - as 6 is our requirement.
Thank you!
psahukaru
got it
Thanks....
Pegasystems
I think that's just a general request for you to launch the "system - > release - > update manager - > system scanner" landing page and gather an inventory and attach it to the request. By knowing what hot fixes you have installed, the analysis of your issue can be more accurate. /Eric
Dear Eric,
Thanks for your response.
