Query Timeout - pyDefaultCaseMatch
Unable to find duplicate case because query is timing out even though optimized properties are used in must match and weighted conditions.
Query:
SELECT "PC0"."pyID" AS "pyID" , "PC0"."pyStatusWork" AS "pyStatusWork" , "PC0"."pxCreateDateTime" AS "pxCreateDateTime" , PegaDATA.pr_read_decimal_from_stream('.pxMatchScore', "PC0".pzInsKey, "PC0".pzPVStream) AS "pxMatchScore" , "PC0"."XYZ" AS "XYZ" , "PC0"."pzInsKey" AS "pzInsKey" FROM PegaDATA.pc_AS_Work "PC0" WHERE ( "PC0"."pzInsKey" <> ? AND UPPER("PC0"."XYZ") = ? AND UPPER("PC0"."pyStatusWork") <> ? ) AND "PC0"."pxObjClass" = ? ORDER BY 4 ASC
Error: There was a problem getting a list: code: 0 SQLState: HY008 Message: The query has timed out.
Any suggestions?
