query to select entire object
I need a way to read the most recently updated version of a data- instance (the entire blob). Ideally I'd like to do this in one trip to the DB and without having to write some custom java. Here's what I've been able to do so far.
1. Use obj-browse to select the pzinskey, and RefreshDateTime properties while sorting by RefreshDateTime in descending order. Also set the max rows to 1 to avoid pulling back too much data. Next use obj-open-by-handle to read the record using the pzinskey retrieved by the obj-browse. This is high frequency use case so making two trips to the DB to get my data is a huge issue.
2. Using obj-browse I can select the entire instance conditionally by date range on RefreshDateTime simply by not checking the "select" checkbox but the results can't be sorted. The SQL does not include the "order by" clause. This negates the ability to sort by RefreshDateTime desc and restrict the number of rows. In order for this to work I'd have to return more rows then use obj-sort to pick the most recently updated record.
