LTIMindtree
Last activity: 7 Dec 2018 5:05 EST
Query Runner help in Pega Infinity Personal Edition
I am using Pega Infinity personal edition where in trying to run select query using Query Runner.
Below is the error it throws :
Unable to fetch SELECT query results select * from pc_assign_worklist;: code: <none> SQLState: The DataStoreConfiguration was not found for the DB Name "pegadata" as it is not registered in the configuration map Message: <none>
DatabaseException caused by prior exception: com.pega.platform.datastore.ConfigurationException: The DataStoreConfiguration was not found for the DB Name "pegadata" as it is not registered in the configuration map
Any help would be appreciated!
You can have a look at the below link.
https://community.pega.com/support/support-articles/query-runner-error-no-data-admin-db-name-instance
