prpcServiceUtils - updateAccessGroup Not Functioning
While performing SSA v7.2.1 Course - Ex: Creating a new application version, I started wondering how you could bulk update all of the app's Access Groups to point to the new version. I found the following Help article "Updating access groups from the command line" at the link below.
- Pega 7.2.2 Online Help Link: https://collaborate.pega.com/pdn.pega.com/files/help_v722/procomhelpmain.htm#sys mgmt/command line tool/sm-prpcServiceUtils-update-access-group-tsk.htm%3FTocPath%3DSystem%2520management%7CService-enabled%2520system%2520management%7C_____7
The help article suggests downloading and using the tool "prpcServiceUtils" and specifying values in the properties for "updateAccessGroup" (my example is listed below). Upon downloading the tool, I configured the files serviceConnection.properties and prpcServiceUtils.properties.
Show More
The help article suggests downloading and using the tool "prpcServiceUtils" and specifying values in the properties for "updateAccessGroup" (my example is listed below). Upon downloading the tool, I configured the files serviceConnection.properties and prpcServiceUtils.properties. I noticed that the following properties were missing from the file prpcServiceUtils.properties, so I added them below the property "user.temp.dir=". I then copied the entire tool package to the SSA VM and applied the necessary permissions.
- updateAccessGroup.applicationName=HRApps
- updateAccessGroup.applicationVersion=01.01.02
- updateAccessGroup.groupList=HRApps:Administrators, HRApps:Authors
Upon execution using the command from the Help article (./prpcServiceUtils.sh updateaccessgroup), it reports the error below. Based on these findings, it appears that the tool does not support updating access groups as documented, unless I'm doing something incorrectly.
- Tool Error: Unknown tool type updateaccessgroup
- prpcServiceUtils.sh export | expose | hotfix |import | getStatus | manageTrackedData | help [options...]
- Remote Configuration Command-line Tool (prpcServiceUtils): https://collaborate.pega.com/exchange/components/remote-configuration-command-line-tool-prpcserviceutils
Thank you for any assistance or direction you can provide.
Show Less
I checked today (June 13), and the updated 7.2.2 version of prpcServiceUtils has been posted to the exchange. Thank you for addressing this request.
This post can be closed as resolved.
