PRPCServiceutil exporting entire application instead of the product
We are able to implement end to end export and import through prpcserviceutil using jenkins. But I can see it's exporting entire application rules instead of the product. We have passed the product name, version and application name, version as parameter. Also the exported file is getting save in pega service export folder, what is the process/command to export it to a file system. Thanks for the assistance.
Hi Arindam,
If your requirement is to export/import only the RAP file then you might use only productName, productVersion and if you want to do for application then you should use applicationName,applicationVersion parameters as specified in the documentation below,
https://community.pega.com/knowledgebase/articles/using-prpcserviceutils-and-jenkins-automated-application-deployment
Hope it might help you.
Mahesh M
