PRPC 6.2 SP1 to 7.3.1 Upgrade takes 7 hours
We are upgrading PRPC 6.2 to 7.3.1. Upgrade utilities runs for 7 hours. We have all configurations like JVM, system disk space and RAM all as per recommendation. Still its taking 7 hours. No DB2 issues while upgrade of rules is running.
Is 7 hours expected time ? or any tuning opportunities. If this install takes 7 hours, then we have other framework, DBA activities on top of it which will make more PROD down time. we don't want to think about split schema at this time based on pros and cons of it.
Can some one suggest , is there a way to run/install/upgrade 7.3.1 with nominal timing ?? and not 7 Hours
You can use the split schema upgrade process to reduce the production downtime. The best approach will be use the lift and shift approach.
this approach should reduce your upgrade time to less than 1 hour.
