softtech
TR
Last activity: 2 Mar 2018 1:28 EST
Provider javax.xml.stream.XMLInputFactory could not be instantiated: java.util.ServiceConfigurationError: javax.xml.stream.XMLInputFactory: Provider com.ibm.xml.xlxp2.api.wssec.WSSXMLInputFactory not found
We are getting the following error while making a SOAP request. Actually we are trying to upgrade our existing applications from PRPC 7.1.7 to 7.3.1. We also changed our application server from WebSphere v8.5 to Liberty Profile. We are calling the connect rule from Datapage. Also i need to mention that there are no logs related with the following exception both on PegaRules Log liberty profile messages.log files. There are only stacktrace entries with PAL I also added the stack trace of them.
2018-02-28 21:40:18,775 [t Executor-thread-56] [ STANDARD] [ ] [ MIYU:01.01.05] ( internal.pal.PALDurationImpl) INFO klpegwlpd1.devisbank|xx.xx.xx.xx 96438 - Attempting to stop timer pxDeclarativePageLoadElapsed/pxDeclarativePageLoadCPU . Timer was not at the top of the stack. Top: pxConnectClientInitElapsed/pxConnectClientInitCPU {java.lang.Exception: com.pega.pegarules.monitor.internal.pal.PALDurationImpl._meStopTiming (PALDurationImpl.java:309)
com.pega.pegarules.monitor.internal.pal.PALDurationImpl.stopTiming (PALDurationImpl.java:363)
com.pega.pegarules.exec.internal.declare.infengine.pages.DeclarativePageDirectoryImpl.runLoadActivity (DeclarativePageDirectoryImpl.java:573)
com.pega.pegarules.session.internal.mgmt.base.handler.EditableDataPageHandler.loadDataPage (EditableDataPageHandler.java:129)
com.pega.pegarules.session.internal.mgmt.base.handler.EditableDataPageHandler.findDataPage (EditableDataPageHandler.java:278)
com.pega.pegarules.session.internal.mgmt.base.AbstractPageDirectory.findDataPageInCurrentDir (AbstractPageDirectory.java:941)
com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.getDataPageByInsKey (ThreadPageDir.java:755)
com.pega.pegarules.session.internal.mgmt.PRThreadImpl.getDataPageByInsKey (PRThreadImpl.java:2309)
com.pega.pegarules.session.internal.mgmt.Executable.findDataPageByInsKey (Executable.java:11015)
com.pegarules.generated.activity.ra_action_pyrunrecordexecute_932948a22903e85292f7fad26db0c420.step3_circum0 (ra_action_pyrunrecordexecute_932948a22903e85292f7fad26db0c420.java:388)
com.pegarules.generated.activity.ra_action_pyrunrecordexecute_932948a22903e85292f7fad26db0c420.perform (ra_action_pyrunrecordexecute_932948a22903e85292f7fad26db0c420.java:109)
com.pega.pegarules.session.internal.mgmt.Executable.doActivity (Executable.java:3597)
com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity (Executable.java:10845)
com.pegarules.generated.activity.ra_action_pzrunrecordexecute_c38281e0bb63f7c4aab88814460c8435.step11_circum0 (ra_action_pzrunrecordexecute_c38281e0bb63f7c4aab88814460c8435.java:1027)
com.pegarules.generated.activity.ra_action_pzrunrecordexecute_c38281e0bb63f7c4aab88814460c8435.perform (ra_action_pzrunrecordexecute_c38281e0bb63f7c4aab88814460c8435.java:246)
com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt (ThreadRunner.java:646)
com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt (PRThreadImpl.java:481)
com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities (HttpAPI.java:3414)
com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner (EngineAPI.java:399)
sun.reflect.GeneratedMethodAccessor66.invoke (null:-1)
sun.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java:55)
java.lang.reflect.Method.invoke (Method.java:508)
com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock (PRSessionProviderImpl.java:1338)
com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked (PRSessionProviderImpl.java:1075)
com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked (PRSessionProviderImpl.java:930)
com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest (EngineAPI.java:336)
com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke (HttpAPI.java:854)
com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact (EngineImpl.java:331)
com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine (EngineImpl.java:274)
com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine (EngineImpl.java:251)
com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner (JNDIEnvironment.java:278)
com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine (JNDIEnvironment.java:223)
com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest (WebStandardImpl.java:678)
com.pega.pegarules.web.impl.WebStandardImpl.doPost (WebStandardImpl.java:394)
sun.reflect.GeneratedMethodAccessor61.invoke (null:-1)
com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod (PRBootstrap.java:370)
com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable (PRBootstrap.java:411)
com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable (AppServerBridgeToPega.java:224)
com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod (AppServerBridgeToPega.java:273)
com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost (WebStandardBoot.java:129)
com.pega.pegarules.internal.web.servlet.WebStandardBoot.doGet (WebStandardBoot.java:100)
javax.servlet.http.HttpServlet.service (HttpServlet.java:687)
javax.servlet.http.HttpServlet.service (HttpServlet.java:790)
com.ibm.ws.webcontainer.servlet.ServletWrapper.service (ServletWrapper.java:1290)
com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest (ServletWrapper.java:778)
com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest (ServletWrapper.java:475)
com.ibm.ws.webcontainer.filter.WebAppFilterChain.invokeTarget (WebAppFilterChain.java:148)
com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter (WebAppFilterChain.java:94)
com.ibm.ws.security.jaspi.JaspiServletFilter.doFilter (JaspiServletFilter.java:57)
com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter (FilterInstanceWrapper.java:207)
com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter (WebAppFilterChain.java:91)
com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter (WebAppFilterManager.java:1021)
com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters (WebAppFilterManager.java:1143)
com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest (CacheServletWrapper.java:82)
com.ibm.ws.webcontainer.WebContainer.handleRequest (WebContainer.java:945)
com.ibm.ws.webcontainer.osgi.DynamicVirtualHost$2.run (DynamicVirtualHost.java:280)
com.ibm.ws.http.dispatcher.internal.channel.HttpDispatcherLink$TaskWrapper.run (HttpDispatcherLink.java:967)
com.ibm.ws.http.dispatcher.internal.channel.HttpDispatcherLink.wrapHandlerAndExecute (HttpDispatcherLink.java:359)
com.ibm.ws.http.dispatcher.internal.channel.HttpDispatcherLink.ready (HttpDispatcherLink.java:318)
com.ibm.ws.http.channel.internal.inbound.HttpInboundLink.handleDiscrimination (HttpInboundLink.java:471)
com.ibm.ws.http.channel.internal.inbound.HttpInboundLink.handleNewRequest (HttpInboundLink.java:405)
com.ibm.ws.http.channel.internal.inbound.HttpInboundLink.processRequest (HttpInboundLink.java:285)
com.ibm.ws.http.channel.internal.inbound.HttpICLReadCallback.complete (HttpICLReadCallback.java:66)
com.ibm.ws.tcpchannel.internal.WorkQueueManager.requestComplete (WorkQueueManager.java:504)
com.ibm.ws.tcpchannel.internal.WorkQueueManager.attemptIO (WorkQueueManager.java:574)
com.ibm.ws.tcpchannel.internal.WorkQueueManager.workerRun (WorkQueueManager.java:929)
com.ibm.ws.tcpchannel.internal.WorkQueueManager$Worker.run (WorkQueueManager.java:1018)
java.util.concurrent.ThreadPoolExecutor.runWorker (ThreadPoolExecutor.java:1153)
java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:628)
java.lang.Thread.run (Thread.java:785)
2018-02-28 21:40:18,775 [t Executor-thread-56] [ STANDARD] [ ] [ MIYU:01.01.05] ( internal.pal.PALDurationImpl) INFO klpegwlpd1.devisbank|xx.xx.xx.xx 96438 - Current elements in Stack [com.pega.pegarules.monitor.internal.pal.PALDurationImpl@162b7758]
2018-02-28 21:40:18,824 [t Executor-thread-56] [ STANDARD] [ ] [ MIYU:01.01.05] ( internal.pal.PALDurationImpl) INFO klpegwlpd1.devisbank|xx.xx.xx.xx 96438 - Trying to stop a timer (in stopAndStart), which has not been started on this Requestor. Stop Timer: pxDeclarativePageLoadElapsed/pxDeclarativePageLoadCPU Stop Count: 1 Start Timer: pxDeclarativeRulesInvokedElapsed/pxDeclarativeRulesInvokedCPU {java.lang.Exception: com.pega.pegarules.monitor.internal.pal.PALDurationImpl.stopAndStart (PALDurationImpl.java:230)
com.pega.pegarules.monitor.internal.pal.PALDurationImpl._meStartRecursiveTimer (PALDurationImpl.java:284)
com.pega.pegarules.monitor.internal.pal.PALDurationImpl.startRecursiveTiming (PALDurationImpl.java:351)
com.pega.pegarules.exec.internal.declare.infengine.InferenceEngineImpl.seekGoalValue (InferenceEngineImpl.java:513)
com.pega.pegarules.data.internal.clipboard.ClipboardPropertyBase.seekValue (ClipboardPropertyBase.java:1423)
com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.autoChain (ClipboardPropertyImpl.java:1218)
com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.autoChain (ClipboardPropertyImpl.java:951)
com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.getStringAndChain (ClipboardPageImpl.java:1942)
com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.getString (ClipboardPageImpl.java:1509)
com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.getString (ClipboardPageImpl.java:1482)
com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.getString (ClipboardPageImpl.java:1478)
com.pega.pegarules.session.internal.mgmt.autostreams.HarnessUIBuilder.getTitle (HarnessUIBuilder.java:401)
com.pegarules.generated.html_harness.ra_stream_activitystatussuccess_773cafa7e6b48853551a4e0065c6cc9d.buildHarnessMarkup_1 (ra_stream_activitystatussuccess_773cafa7e6b48853551a4e0065c6cc9d.java:3438)
com.pegarules.generated.html_harness.ra_stream_activitystatussuccess_773cafa7e6b48853551a4e0065c6cc9d.performStream_15 (ra_stream_activitystatussuccess_773cafa7e6b48853551a4e0065c6cc9d.java:3591)
com.pegarules.generated.html_harness.ra_stream_activitystatussuccess_773cafa7e6b48853551a4e0065c6cc9d.execute (ra_stream_activitystatussuccess_773cafa7e6b48853551a4e0065c6cc9d.java:124)
com.pega.pegarules.session.internal.mgmt.Executable.getStream (Executable.java:4136)
com.pega.pegarules.session.internal.mgmt.Executable.getStream (Executable.java:3958)
com.pegarules.generated.activity.ra_action_show_harness_38c1e950e2ed0560df24e75dcd8a7552.step7_circum0 (ra_action_show_harness_38c1e950e2ed0560df24e75dcd8a7552.java:746)
com.pegarules.generated.activity.ra_action_show_harness_38c1e950e2ed0560df24e75dcd8a7552.perform (ra_action_show_harness_38c1e950e2ed0560df24e75dcd8a7552.java:173)
com.pegarules.generated.activity.ra_action_activitystatusnocontenthandler_abf91e663cdc15170bb5fb44e777dd3c.step2_circum0 (ra_action_activitystatusnocontenthandler_abf91e663cdc15170bb5fb44e777dd3c.java:217)
com.pegarules.generated.activity.ra_action_activitystatusnocontenthandler_abf91e663cdc15170bb5fb44e777dd3c.perform (ra_action_activitystatusnocontenthandler_abf91e663cdc15170bb5fb44e777dd3c.java:87)
com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.postProcessContent (HttpAPI.java:3810)
com.pega.pegarules.session.external.engineinterface.service.EngineAPI.activityExecutionEpilog (EngineAPI.java:578)
com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner (EngineAPI.java:476)
2018-02-28 21:40:18,824 [t Executor-thread-56] [ STANDARD] [ ] [ MIYU:01.01.05] ( internal.pal.PALDurationImpl) INFO klpegwlpd1.devisbank|xx.xx.xx.xx 96438 - Current elements in Stack [com.pega.pegarules.monitor.internal.pal.PALDurationImpl@162b7758]
