Capgemini
BR
Last activity: 8 Feb 2020 17:25 EST
Problems using IAC in MashUp
I am using Pega MashUp and I have identified the following problems:
When I use the code below in the development environment, it works correctly and displays the desired screen
<script src ='http:// Proprietary information hidden/prweb/PRServlet?pyActivity=pzIncludeMashupScripts'></script>
<div data-pega-gadgetname ='PegaGadget'
data-pega-action ='OpenWorkByURL'
data-pega-action-param-query ='pyActivity=Data-Portal.ShowDesktop'
data-pega-isdeferloaded ='false'
data-pega-applicationname ='Oficinas'
data-pega-threadname ='STANDARD'
data-pega-systemid ='PEGA_DEV'
data-pega-resizetype ='stretch'
data-pega-url ='http:// Proprietary information hidden/prweb/IAC'
data-pega-action-param-parameters="{UserIdentifier:'oficina'}"
data-pega-redirectguests ='false' ></div>
However, when I modify the address, that is, the environment, Pega is unable to identify the application indicated in the data-peg-applicationname = 'Workshops' tag
2020-01-28 20: 37: 03,617 [ch Thread t = 008ba140] [STANDARD] [] [] (ngineinterface.service.HttpAPI) ERROR Proprietary information hidden | Proprietary information hidden - Exception occured:
com.pega.pegarules.pub.context.PRSecurityException: Unknown Application: Workshops
What could have generated this error? What kind of assessment should I apply? Is it an IAC specific problem?
Can You help me ?
