Problems regarding "ContextInitialized" in the process of Upgrade from 7.2.1 to 7.3
Hello Everyone,
We are in the process to upgrade an in house environment from 7.2.1 to 7.3. We are using 'the UI tool' to do the same.
Application Server: Tomcat
DB: Posgresql
After successfully, executing the UI Tool (filled in with DB details etc), we try to deploy * prweb.war * from the archive folder of the 7.3zip file (from pega) in the tomcat manager console. While doing so: we find - we encounter the below errors. And thereby the pega server 7.3 is also not up and running.
Please do let us know, if you have something helpful in mind.
The error details :
============ PegaRULES Bootstrap Configuration ============
Date: Mon Oct 02 05:14:49 EDT 2017
Java Version: Oracle Corporation 1.8.0_51
Configuration: file:/pega/prpc721/_dev/workspace/Servers/Tomcat70_Default-config/webapps/prweb/WEB-INF/classes/prbootstrap.properties
Pega-EngineCode: 07-10-31
ASM Version: 762781845
Database: PostgreSQL 9.3.9
Driver: PostgreSQL JDBC Driver 42.1.4
Active CodeSets: pega-enginecode:07-10-31 at (latest patch)
customer:06-01-01 at (latest patch)
=============== End Bootstrap Configuration ===============
Oct 02, 2017 5:14:53 AM com.pega.pegarules.internal.bootstrap.SettingReaderJNDI
INFO: Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
Hello Everyone,
DB: Posgresql
The error details :
INFO: Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
Oct 02, 2017 5:15:26 AM com.pega.pegarules.internal.bootstrap.PRBootstrap
SEVERE: Problem during method invocation (contextInitialized)
java.lang.ExceptionInInitializerError
at com.pega.platform.message.internal.broadcast.NotificationModule.getInstance(NotificationModule.java:77)
at com.pega.platform.message.internal.broadcast.PRNotificationModule.<init>(PRNotificationModule.java:17)
at com.pega.platform.message.internal.broadcast.PRNotificationModule$NotificationModuleLoader.<clinit>(PRNotificationModule.java:27)
at com.pega.platform.message.internal.broadcast.PRNotificationModule.getInstance(PRNotificationModule.java:21)
at com.pega.pegarules.session.internal.serverpush.PushServerFactory.initialize(PushServerFactory.java:67)
at com.pega.pegarules.session.internal.serverpush.PushServerFactory.<init>(PushServerFactory.java:51)
at com.pega.pegarules.session.internal.serverpush.PushServerFactory.<clinit>(PushServerFactory.java:40)
at com.pega.pegarules.session.internal.serverpush.PushComponentProvider.getPushLifecycle(PushComponentProvider.java:48)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener.initializePushEngine(WebAppLifeCycleListener.java:482)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextInitialized_privact(WebAppLifeCycleListener.java:425)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener.contextInitialized(WebAppLifeCycleListener.java:221)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:5017)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5531)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:652)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1095)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1930)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.NullPointerException
at com.pega.pegarules.cluster.internal.PRClusterImpl.getPRSysStatusNodesInformation(PRClusterImpl.java:659)
at com.pega.pegarules.cluster.internal.PRClusterImpl.canInitialize(PRClusterImpl.java:322)
at com.pega.pegarules.cluster.internal.PRClusterImpl.getInstance(PRClusterImpl.java:246)
at com.pega.pegarules.cluster.internal.PRClusterProviderImpl.getInstance(PRClusterProviderImpl.java:98)
at com.pega.platform.message.CoreMessage.getInstance(CoreMessage.java:71)
at com.pega.platform.message.internal.broadcast.NotificationModule.<init>(NotificationModule.java:65)
at com.pega.platform.message.internal.broadcast.NotificationModule$NotificationModuleLoader.<clinit>(NotificationModule.java:58)
... 33 more
Oct 02, 2017 5:15:26 AM com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega
... 33 more
Oct 02, 2017 5:15:26 AM org.apache.catalina.core.StandardContext startInternal
SEVERE: One or more listeners failed to start. Full details will be found in the appropriate container log file
SEVERE: Context [/prweb] startup failed due to previous errors
Oct 02, 2017 5:15:28 AM com.pega.pegarules.internal.bootstrap.PRBootstrap
SEVERE: Problem during method invocation (contextDestroyed)
at com.pega.pegarules.cluster.internal.PRClusterHazelcastImpl.shutdown(PRClusterHazelcastImpl.java:1250)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextDestroyed_privact(WebAppLifeCycleListener.java:179)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener.contextDestroyed(WebAppLifeCycleListener.java:115)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextDestroyed(WebAppLifeCycleListenerBoot.java:67)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:5064)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5726)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:232)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:160)
Oct 02, 2017 5:15:28 AM com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega
