Problem invoking function: pega_importexport_pximportexport.pxHasSchemaChanges--(Boolean), The argument did not contain a SELECT token.
Our enviroment has just been upgraded from Pega version 7.1.8 to 7.2.2., after which I have an issue importing a package.
The package contains a connection to a MS SQL DB, which is already present on the environment I am trying to import it on. Actually, the same package has been imported to this environment before, in version 7.1.8.
After selecting the right file in the Import Wizard and clicking Next, the following error is shown:
- The Flow Action post-processing activity pxSetShowAllSteps failed: Problem invoking function: pega_importexport_pximportexport.pxHasSchemaChanges--(Boolean), The argument did not contain a SELECT token.
Further investigation shows that Pega sends this query to that SQL DB:
It tries to execute a stored procedure using a select operation, which results in the error.
Does anyone else have this problem and if so, have a solution?
DB Trace Database Name Test Table Name Test SQL Operation select SQL {call sp_helptext(?)} SQL Inserts <Test>
| [MSG][Exception][STACK][com.pega.pegarules.pub.runtime.LibraryFunctionNotFoundException: Problem invoking function: pega_importexport_pximportexport.pxHasSchemaChanges--(Boolean), The argument did not contain a SELECT token. at com.pega.pegarules.generation.internal.library.LibraryRuntime.resolveAndinvokeFunctionViaReflection(LibraryRuntime.java:246) at com.pega.pegarules.generation.internal.library.LibraryRuntime.invokeLibraryRuntime(LibraryRuntime.java:119) at com.pega.pegarules.session.internal.mgmt.Executable.invokeLibraryRuntime(Executable.java:9105) at com.pega.pegarules.priv.generator.LibrarySupport.resolveAndInvokeFunctionViaReflection(LibrarySupport.java:258) at com.pegarules.generated.pega_importexport_pximportexport.pxHasSchemaChanges(pega_importexport_pximportexport.java:342) at com.pegarules.generated.pxHasSchemaChanges_071017_Rm023mqcn95hL8_DJe7q6g.pxHasSchemaChanges07_10_17(pxHasSchemaChanges_071017_Rm023mqcn95hL8_DJe7q6g.java:100) at com.pegarules.generated.pxHasSchemaChanges_071017_Rm023mqcn95hL8_DJe7q6g.invoke(pxHasSchemaChanges_071017_Rm023mqcn95hL8_DJe7q6g.java:82) at com.pega.pegarules.generation.internal.library.LibraryRuntime.resolveAndinvokeFunctionViaReflection(LibraryRuntime.java:221) at com.pega.pegarules.generation.internal.library.LibraryRuntime.invokeLibraryRuntime(LibraryRuntime.java:119) at com.pega.pegarules.session.internal.mgmt.Executable.invokeLibraryRuntime(Executable.java:9105) at com.pega.pegarules.priv.generator.LibrarySupport.resolveAndInvokeFunctionViaReflectionWithException(LibrarySupport.java:275) at com.pegarules.generated.activity.ra_action_pxcontainsschemaarchive_5ca833663034c86fb207c2b1ae4eea65.step1_circum0(ra_action_pxcontainsschemaarchive_5ca833663034c86fb207c2b1ae4eea65.java:183) at com.pegarules.generated.activity.ra_action_pxcontainsschemaarchive_5ca833663034c86fb207c2b1ae4eea65.perform(ra_action_pxcontainsschemaarchive_5ca833663034c86fb207c2b1ae4eea65.java:70) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3553) at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10711) at com.pegarules.generated.activity.ra_action_pxsetshowallsteps_c91b43539aa22807661e90fa53ee8440.step2_circum0(ra_action_pxsetshowallsteps_c91b43539aa22807661e90fa53ee8440.java:316) at com.pegarules.generated.activity.ra_action_pxsetshowallsteps_c91b43539aa22807661e90fa53ee8440.perform(ra_action_pxsetshowallsteps_c91b43539aa22807661e90fa53ee8440.java:93) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3553) at com.pegarules.generated.callActivity_071027_yoB3RheCwDdLlLDKhZ4s2w.callActivity07_10_27(callActivity_071027_yoB3RheCwDdLlLDKhZ4s2w.java:133) at |
