Capgemini
Last activity: 14 Oct 2016 10:50 EDT
postgresql 9.3 could not load library pljava.dll %1 is not valid win32 application
I am installing Pega 7.2.1 on Apache Tomcat and Postgresql 9.3 version. As per the instructions had installed postgresql 9.3.5 x64.exe.
Copied the pljava.jar and pljava.dll file from the resource kit to postgres lib directory. Also updated the postgresql.conf file as instructed.
On a windows 2008R2 server 64 bit and jdk 1.7.
When I try to run the install sql , I keep getting an error "ould not load library pljava.dll %1 is not valid win32 application". I did try both 32 bit and 64 bit Postgresql but in all cases get the same error.
Can anyone advise me how to fix this.
The error suggests that pljava.dll and pljava.jar were not deployed or your system is not allowing you to install .dll files. Please check you should have admin rights and avoid installing postgresql in C:/Program files location.
