Performance testing using Webload
Does anyone have ever used Webload for performance testing with a Pega application ?
Is there any documentation for using Webload with Pega?
We face some issue and not sure how to handle it.
In fact, Webload works the following way :
- A user login to our Pega application and from the dashboard on a widgets showing lines of different clients, they click on one link which open a 360 view (create a new Interaction)
- Webload record every transaction made by Pega during those user actions in a script
- For performance testing Webload play back this script executing the exact same transactions with same parameters
The issue is that, as they are not executing actions on the UI, how can they open multiple and different 360 views for different Clients with this single script ?
Is it possible, and if yes, what to change in theses recorded transactions ?
It appears that Pega’s transactions include many dynamic portions that are not suitable to just be recorded and played back.
Thank you.
