Pega's published process schema in "Publicflow.xml" file in Pega Platform
here https://support.pega.com/question/import-process-models-pega was discussed a need for mapping of BPMN2.0 with Pega Flow or even Pega Case Type and Flow today.
That need still exists heavily in context of Government opportunities to name a major one.
The referenced schema file "publicflow.xml" still exists in Pega. It seems not to be the schema that is used for storing a flow rule internally.
Is this publicflow.xml schema explained or accompanied by a documentation that exists anywhere?
Do examplary files exist that conform to this schema and express a Pega flow or Pega case type + flows?
A wizard exists to import from that schema, but I couldn't test it, because I do not have access to a schema-conformant file.
Does Pega support also an export into a file written in that schema?
Regards
Markus
