Capgemini
Last activity: 24 Jun 2020 6:27 EDT
#PegaHackathon2020 change node to Universal
Hi Team,
Can you please enable change the node type to universal in our community edition. Thanks in advance.
@MattE - Thanks in advance.
Updated: 24 Jun 2020 6:27 EDT
Hi Vinoth - I noticed that your system powered off, so I made the change. The next time you power it up, your node will be type Universal
Hi Vinoth - sure, let me know when you're ready and I can change the node type and reboot the server.
Capgemini
Thanks much Matte.
Capgemini
Hi @MattE - After the node change I could not login to my community edition server. Could you please look into the issue.
Thanks in advance
Updated: 18 Jun 2020 9:04 EDT
Hi Vinoth - the issue was that you changed the production level of your system from 4 to 1, which changes the DB that sso externally authenticate against. This change doesn't go into effect until after a restart, which is why you started seeing issues after the node change - it was the reboot rather than the node change itself. I set your system back to level 4 and you should be good to log in again now.
Capgemini
Hi @MattE - Thanks much for the quick analysis and help. I could see my system's browser type requestor was pointing to "PTC:Unauthenticated" I am reverting this as this blocks my implementation.
Hope this doesn't break my application again :-)
Hi Vinoth - Changing the browser type to not see PTC:Unauthenticated rules will break the /sso login screen, yes. I recommend either building an Unauthenticated access group that works for both MCC and PTC rules or creating a non-sso operator to use to log into your app.
Capgemini
Hi @MattE - I am going with the first option that you have recommended. In my Unauthenticated Access Group I have added the "PTC-Authentication" as one of the Production Rulesets in the Run Time Configuration under the Advanced tab.
By doing this I think my Unauthenticated access group will work for both MCC and PTC rules. Please correct me if I am wrong.
Hi Vinoth - I think you might need the PegaPCDIntegration ruleset as well as PTC-Authentication. Or you could just add the TrialAuthentication:01.01.01 application to your app stack and that would do it.
It's easy to test. Make sure you stay logged in just in case it breaks and open an incognito or private session and verify you can see the login screen and login.
Capgemini
Hi Matte - I have added TrialAuthentication:01.01.01 application to my app stack and tested logging in with another session. Its works fine.
Thanks much for your help.
