Pega work Flow Send Parameters
how to send the Stage 1 parameter to Stage 2, show in stage 2 label.
set the parameter in stage 1 and use the parameter in stage 2 with format as 'param.<param_name>'
Pega Support Center has detected you are using a browser which may prevent you from experiencing the site as intended. To improve your experience, please update your browser.
