Pega Robotics Studio: passing strings into scripts
I noticed that if my script has a string or String parameter:
- if I call it passing the string from a String variable, it works, but
- if I call it directly typing the string into the parameter, it does not.
"Does not work" means the value is null when seen from inside the script.
Please refer to the images. Is there any reason for this, and any way to remove this restriction?
