State Farm Mutual Automobile Insurance Company
Last activity: 11 Jan 2018 8:22 EST
Pega Robotics - Hook PDFCreator to be able to use the email feature when printing
I am working on a project where from a web browser I want to print the page using PDFCreator. I have tried and not been able to have PDFCreator to open for interrogation. The path is set to the PDFCreator.exe and Start Method: Monitor All. From there I start interrogation and open a browser and go through the steps to print to PDF using PDFCreator. When I get to the PDFCreator window from the print dialog it will open PDFCreator but while it is starting a window pops up saying "PDFCreator has stopped working". This is the only method I can even get something to happen as setting StartMethod: Start the "PDFCreator has stopped working" shows up immediately. I would really like to be able to use PDFCreator for this, as it provides me with a function other PDF print applications available to me do not. Any idea how to get this to work?
You would need to open a Support Request to request support for this application (which can take some time). You may have some alternative way of working with it by checking if there are command line options for the application.
What can this application do that others can't? You could also consider to try using a PDF C# library that would also meet your needs.
