Staidlogic LLC
Last activity: 13 Sep 2019 10:12 EDT
Pega Robotics Excel Text to Column not working
Using Excel 2016 Connector, I am trying to use basic text-to-column function of a selected range in excel file. But the function TextToColumns() gives error. Not sure where the problem is. It is simple single column excel with data separated with ;
1) Exception Information
Exception Type: OpenSpan.Automation.AutomationException
EventLink: OpenSpan.Automation.EventLink
ThrowingLink: OpenSpan.Automation.EventLink
CreatedDateTime: 9/11/2019 3:52:38 PM
AppDomainName: "OpenSpan.Runtime.exe"
ThreadIdentityName: ""
AdditionalInformation: NameValueCollection with 0 items
Message: "Error executing link in Automation: Automation1 - From: Automation1.variable1.Properties To: Automation1.rangeProxy4.TextToColumns()
TextToColumns method of Range class failed"
Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items
TargetSite: Void Execute(System.Object, OpenSpan.Automation.ExecutionEventArgs)
HelpLink: NULL
Source: "OpenSpan.Automation"
HResult: -2146232832
StackTrace Information
at OpenSpan.Automation.EventLink.Execute(Object sender, ExecutionEventArgs e)
at OpenSpan.Automation.EventLink.OnReceiveEvent(Object sender, ExecutionEventArgs e)
at OpenSpan.Automation.ConnectableWorker.DoWork(Object sender, ExecutionEventArgs executionArgs)
HelpLink: NULL
2) Exception Information
Exception Type: System.Runtime.InteropServices.COMException
ErrorCode: -2146827284
Message: "TextToColumns method of Range class failed"
TargetSite: System.Object ForwardCallToInvokeMember(System.String, System.Reflection.BindingFlags, System.Object, Int32[], System.Runtime.Remoting.Proxies.MessageData ByRef)
HelpLink: "xlmain11.chm"
Source: "Microsoft Excel"
HResult: -2146827284
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Microsoft.Office.Interop.Excel.Range.TextToColumns(Object Destination, XlTextParsingType DataType, XlTextQualifier TextQualifier, Object ConsecutiveDelimiter, Object Tab, Object Semicolon, Object Comma, Object Space, Object Other, Object OtherChar, Object FieldInfo, Object DecimalSeparator, Object ThousandsSeparator, Object TrailingMinusNumbers)
