Pega Robotics Differentiators
Kindly share inputs for differentiators
Show More
| Blue Prism Ver (6.3) | Pega Robotics 8.0 | |
| Bot Types | Supports only unattended automation | |
| Licensing Model | More Flexible | |
| Multi Tenancy | Added the multi-team environment feature in v6.3 which enables customers to create multiple teams with varying levels of permission and access to Processes, Objects and Resources |
| Ease of Development | Lower as compared to UiPath & AA with no recording feature and | |
| Security Features | BP scores slightly higher on this | |
| Event Based Triggers | BP does not provide event based triggers. | |
| Version Control Integration | No native integration with Third party tools. | |
| Work Queues | Available since inception of Tool | |
| MI Reports | Out of box reporting features available like reporting tables, scheduled job to populate schema with standard dashboard. | |
| Cognitive Roadmap | BP is relying on external partnership like intelligent system and also offers VBO to integrate with Google, IBM Watson & Microsoft Cognitive services. | |
| Windows 10 Support | •Fully Supported | |
| Architecture | •Bot Exe interacts with App Server Exe through WCF (TCP/IP) protocol and .NET Remoting. | |
| •All communication can be secured using certificate based authentication | ||
| •App Server Connects to DB | ||
| Code Files | •Source Code files stored in SQL DB | |
| •Bot extracts code from DB while execution happens on Bot VM | ||
| Configuration Management Integration | •Source Code stored in DB hence no out of Box integration with CM tools like SVN possible. | |
| •Provides inbuilt version control mechanism which offers limited features. | ||
| Credentials Vault | •Inbuilt credentials vault to store third party credentials encrypted using latest algorithm in file share. | |
| Encryption Algorithms for storing Credentials | •Offers Multiple Encryption Algorithm. | |
| •provision to utilize manual or automated generated Key. | ||
| •Provision to store key manually and add custom Access restrictions. | ||
| Communication | •Bots access credentials decrypted at App Server. | |
| •Shared with client in plain text through secured channel (WCF using TCP\IP Protocol or .NET Remoting) | ||
| CyberArk Integration | •Out of Box Cyber Ark Integration available | |
| Work Queues | •Provision mechanism to utilize Encryption Algorithm to encrypt & store Work Queues items in databases. | |
| Ability to Run Bots with locked Desktop | •Bots need to unlock desktop\VM, provides Log In Agent functionality to execute own its own. | |
| Work Queues Supported | Work Queues available since inception of product | |
| Item level Locking | Available | |
| Defer Until / Postpone Item Processing | Available | |
| Encryption of WQ items | Available | |
| Tagging to filter items | Available | |
| Retry Feature to process items marked as Exception | Available | |
| Ability to Mark Exception Programmatically | Available | |
| Filter Queues Programmatically | Available | |
| Priority Assignment at Item level | Available |
Show Less
