Pega Platform 7.4
Are all uplifts to 7.4 upgrades? In the Digital Software library all other versions have an "update" entry but 7.4 does not.
Hello!
Thank you for posting on PSC. Pega 7.4 is our latest Pega version.
https://community.pega.com/knowledgebase/products/platform
Let us know your use case if you need more help!
Hi, has Pega released 7.4.1 to the public yet? If so, where can we find the release notes? If not, when will 7.4.1 be released?
As far as I'm aware, 7.4 has a separate update media that you can download and use.
Thanks. If that is the case (separate update media), then where can I locate it? This is what I see when I try to access the versions available.
Doesn't seem like the word component save. I'll try to attach a file.
Scroll all the way to the bottom: there is 7.4 Update media there.
