Pega Personal edition 8.4 installation issues(Tons of them)
Hello I have downloaded pega personal edition 8.4 from pega pdn. I am getting lots of errors while installing in my Windows 10 laptop.
BUILD FAILED C:\*******\pega\8.4\pegaGuiInstallerTemp\build.xml:164: java.lang.ClassCastException: class jdk.internal.loader.ClassLoaders$AppClassLoader cannot be cast to class java.net.URLClassLoader (jdk.internal.loader.ClassLoaders$AppClassLoader and java.net.URLClassLoader are in module java.base of loader 'bootstrap') at com.pega.pegarules.util.anttasks.IsDBAvailable.addJar(IsDBAvailable.java:59) at com.pega.pegarules.util.anttasks.IsDBAvailable.execute(IsDBAvailable.java:83) at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292) at jdk.internal.reflect.GeneratedMethodAccessor8.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:564) at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106) at org.apache.tools.ant.Task.perform(Task.java:348) at org.apache.tools.ant.Target.execute(Target.java:435) at org.apache.tools.ant.Target.performTasks(Target.java:456) at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1393) at org.apache.tools.ant.Project.executeTarget(Project.java:1364) at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41) at org.apache.tools.ant.Project.executeTargets(Project.java:1248) at org.tp23.antinstaller.antmod.Main.runBuild(Main.java:710) at org.tp23.antinstaller.antmod.Main.startAnt(Main.java:218) at org.tp23.antinstaller.antmod.Launcher.run(Launcher.java:216) at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79) at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88) at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Total time: 37 seconds org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:91) at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88) at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398) Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:81) ... 2 more --- Nested Exception --- org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:81) at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88) at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Can some one please help.
