Pega Notification stops working and starts only upon server restart
I added pxNotify in an activity and set Param.NotificationName and Param.RecipientsList as one of the operators who need the notification. (Not the current operator). This is working fine and I could get the bell icon displayed in top right of the port. But, this is getting stopped in a while and I could make it work once server restarted. All the old notifications also displayed once server restarted.
Could anyone help on finding the root cause of the issue as we cannot restart every time when notification are not working?
@Nirushiya I think pega uses a queue processor in the backend to generate these notifications. We face this kind of issue, when the stream node goes down intermittently.
If it happens again, can you go to Configure->Decisioning->Infrastructure->Stream and check the status. If the status is "Normal" that you can rule this theory out. But if the stream node is down, then some more investigation would be needed at your end to find the root cause of it.
Regards
Bhavya
