NJCourts
Last activity: 11 Oct 2023 21:37 EDT
Pega Mash up dynamic parameters in script are not changing after first time - SAML SSO login
Hi, We have java application invokes pega mash up script using SAML SSO url in it. The action is display a page. Java app passes two parameters dynamically required to laod the data in harness in pega. Pega is reading these parameters for first time when the script is invoked. Then after, every time java app invokes the script , the parameter values are not changing through new values are being sent through script. Hence, the same data loads everytime after first load.
We tried terminating requestor sessions but didn't work. we tried with encryption tunred off, but no luck.
Any leads to this are much appreciated. Thank you.
