Pega Marketting Course - VM is not inititalizing when trying to install using Virtual Box
Hi ,
I downloaded Pega Marketing Enablement 7.21 ML0.VBOX from PDN and installed Virtual box to run the marketing vbox file.
I followed all the steps judiciously as given in the installation guide,
But when i started the VM i got a blank command screen unlike the login screen.I thought it was a load issue and tried to access the URL: http://192.168.56.111 but it did not load.(Screenshot attached)
I have tried to run several other applications like LSA 7 as well and faced the same issue.Could you please advice if this is an issue with my laptop config.
My laptop config is as below
Processor : AMD A4-6210 APU with AMD Radeon R3 graphics
RAM : 4 GB
System type : 64 bit OS , x64-based processor
Windows edition : Windows 10 Home
***Moderator Edit: Vidyaranjan | Moved from PSC to Academy***
