Nokia Solutions and Networks
Last activity: 6 Jan 2026 16:26 EST
PEGA Constellation: Embedded Data(Pagelist)
Hi team,
I have a Scenario where the data is not getting updated in View(UI) for Pagelist property when the update(edit) of the record is performed. i.e., In Data class created 3 Properties, Out of 3 properties 1 property is picklist and other 2 Properties are Text.
Actual logic Picklist has two values(A and B) is when the user selects A then user will able to provide information for 2nd Property, 3rd Property will not be visible in the UI. when the user selects B then 2rd Property will not be visible in the UI. the user will able to provide information for 3nd Property.
Initially, I created 2 records in the Pagelist, Later I updated the 1st record from option A to B, then 2nd Property is not visible on the pop-up UI, I was able to enter the data for 3rd field on pop-up UI. Once I enter the data for 3rd property. On UI I was able to see the data for 2nd(old data) and 3rd property.
