CGI
Last activity: 8 Dec 2020 6:28 EST
Pega API - FileNotFoundException
Project recently upgraded several non-prod environments to v8.4 from V7.2. In the dev environment, I have no problem in sending the REST command to get node info. But in the testing environment, when I open the Pega API screen, it fails to load all the API commands. It just shows me the category and when expand it, it is empty. I also try to construct the REST command using the command in the dev environment
https://<server ip>:<port>/prweb/api/v1/nodes
and I get the following error:
Error 404: java.io.FileNotFoundException: SRVE0190E: File not found: /api/v1/nodes
What am i missing?
Thanks in advance.
Ben
