Pega 7.4 - dual user configuration - optimize schema - create indexes not working
We are using Pega 7.4 with SQL Server 2016 and tomcat.
During my review on the compliance score I discovered some report that may need indexes.
I went to the Optimize schema page and tried to add some indexes.
I got the following message :
Cannot find the object "DATA.PR_XXX_YYY_ZZZ_DATA_LOCAT" because it does not exist or you do not have permissions.
Last SQL: CREATE INDEX EXCHANGEIndex ON DATA.PR_XXX_YYY_ZZZ_DATA_LOCAT ("EXCHANGE")
I checked with database profiler and found that the base user is used, not the admin user.
Context.xml is set like this :
<Resource name="jdbc/PegaRULES"
auth="Container"
factory="org.apache.tomcat.jdbc.pool.DataSourceFactory"
type="javax.sql.DataSource"
driverClassName="com.microsoft.sqlserver.jdbc.SQLServerDriver"
url="jdbc:sqlserver://database;selectMethod=cursor;sendStringParametersAsUnicode=false"
username="base_user"
password="password"
maxActive="100"
maxIdle="30"
testWhileIdle="true"
maxWait="10000"
testOnBorrow="true"
validationQuery="SELECT 1"
jdbcInterceptors="org.apache.tomcat.jdbc.pool.interceptor.ConnectionState;org.apache.tomcat.jdbc.pool.interceptor.StatementFinalizer"
auth="Container"
password="password"
maxActive="100"
maxIdle="30"
maxWait="10000"
testOnBorrow="true"
<Resource name="jdbc/AdminPegaRULES"
auth="Container"
username="admin_user"
password="password"
maxActive="10"
initialSize="5"
minIdle="5"
maxIdle="5"
maxWait="5000"
testOnBorrow="true"
<Environment
name="prconfig/database/databases/PegaRULES/dataSourceAdmin"
value="java:comp/env/jdbc/AdminPegaRULES"
type="java.lang.String"
<Environment
name="prconfig/database/databases/PegaDATA/dataSourceAdmin"
<Environment
name="prconfig/database/databases/PegaRULES/defaultSchema"
value="rules"
<Environment
name="prconfig/database/databases/PegaDATA/defaultSchema"
value="data"
As you can see admin user is set for both rules and data schema for datasourceadmin.
I don't understand why to optimizeSchema doesn't use the admin profile, is it normal?
Also, SQL rights are set as follow :
Admin :
ALTER AUTHORIZATION ON SCHEMA::[rules] TO admin_user
ALTER AUTHORIZATION ON SCHEMA::[data] TO admin_user
GRANT CREATE TABLE, CREATE VIEW, CREATE PROCEDURE , CREATE FUNCTION,CREATE ASSEMBLY, EXECUTE TO admin_user;
GRANT ALTER ON SCHEMA :: data to admin_user;
GRANT ALTER ON SCHEMA :: rules to admin_user;
Base:
GRANT SELECT , INSERT, UPDATE, DELETE, EXECUTE ON SCHEMA :: data TO base_user;
Could you help to find what is the issue?
Thank you
Upon reviewing the associated Support Request, I see that HFix-48160 was provided to resolve.
Additional notes from the SR:
For this hotfix to work, the administrator datasource and the corresponding environment entries that specify the administrator datasource for both PegaRULESand PegaDATA schema must be provided in the Application Server configuration.
Use the following context.xml entries in the case of Tomcat server:
<Resource name="jdbc/AdminPegaRULES" auth="Container" type="javax.sql.DataSource" driverClassName="com.microsoft.sqlserver.jdbc.SQLServerDriver" url=...
<Environment name="prconfig/database/databases/PegaDATA/dataSourceAdmin" value="java:comp/env/jdbc/AdminPegaRULES" type="java.lang.String"/>
<Environment name="prconfig/database/databases/PegaRULES/dataSourceAdmin" value="java:comp/env/jdbc/AdminPegaRULES" type="java.lang.String"/>
