Pega 7.2.x Server hardware and virtual machine dependency
Hi Team,
We are referring to platform support guide PDF available at the https://collaborate.pega.com/discussion/prpc-5x-6x-platform-support-guide-easy-find.
As per the PDF Server hardware is listed only for 7.2.2 and not for 7.2.1. We assume that server hardware is common for both these versions of PRPC.
Please confirm if our assumption is valid.
And there only 5 server hardware names listed in the document under Server Hardware section. So does this mean that other servers hardware should not be used for installing Pega PRPC 7.2.2/7.2.1?
If we are hosting PRPC in IBM Web Sphere installed on a virtual machine will server hardware still be a matter of concern for us?
Please provide your feedback.
Vivek
Hi Vivek,
Please refer the attached guide for 7.2.1. It is having all the information you are looking for.
Answer for your query:
Yes, you are right. It means PRPC is certified/tested on these specific platforms and recommended to use the same.
Sudhish OP
