Pega 7.2.2 integration with External database in Tomcat 7.0.69 - Linux - jdbc/DBNAME JNDI not bound error
Does any one faced similar issue during External database integration using connection pool configuration in Tomcat 7.0.69 - Linux. Any suggestion?
1) Added Resource in tomcat conf Context.xml file
<Context ...>
<Resource name="jdbc/EmployeeDB"
auth="Container"
type="javax.sql.DataSource"
username="dbusername"
password="dbpassword"
driverClassName="org.hsql.jdbcDriver"
url="jdbc:HypersonicSQL:database"
maxActive="8"
maxIdle="4"/>
</Context>
2) prweb.war - web.xml - Added resource reference.
<resource-ref>
<description>
EmpDB mapping
</description>
<res-ref-name>
jdbc/EmployeeDB
</res-ref-name>
<res-type>
</res-type>
<res-auth>
Container
</res-auth>
</resource-ref>
3) Created a Database rule and mapped to Use Connection Pool option and used jdbc/EmployeeDB
We are getting the following error during test connection from the database configuration rule in Pega UI.
The DataSource jdbc/EmployeeDBis invalid: Unable to obtain DataSource object: code: <none> SQLState: Name [jdbc/EmployeeDB] is not bound in this Context. Unable to find [jdbc]. Message: <none>
DatabaseException caused by prior exception: javax.naming.NameNotFoundException: Name [jdbc/EmployeeDB] is not bound in this Context. Unable to find [jdbc].
<Context ...>
auth="Container"
maxActive="8"
maxIdle="4"/>
</Context>
<resource-ref>
<description>
EmpDB mapping
</description>
<res-ref-name>
jdbc/EmployeeDB
</res-ref-name>
<res-type>
</res-type>
<res-auth>
Container
</res-auth>
</resource-ref>
***Edited 5/19/17 by Moderator, Maryrita: moved to PSC from Upgrade Center***
