Unisys
Last activity: 18 Jul 2016 8:56 EDT
Pega 7.2 connect to external mysql DB using SQL connector from pega
Hi I am using Pega 7.2. I'm trying to connect to external mysql DB using SQL connector from pega. The column in my external db are of type integer. After running Connector and metadata wizard, all activities are generated but when I run OPEN or BROWSE activity I get the error property 'xyz' not exposed. And when I try to Optimize that particular property from the generated class, I get the following error "
No Valid classes in the hierarchy
Unable to perform property optimization: The table mapped to this class does not have a stream column, so there is no property information to expose. The column must be created manually.
Pls give me suggestions/ideas to fix this issue its very urgent
Thanks For help.
Akshay
***Updated by moderator: Lochan to add Categories
