Parsing JSON response containing single text. Getting JsonMappingException
Created a Connect-REST service with PUT request method as per the service requirement. When successful i.e. pyHTTPResponseCode=200 the service responds with following JSON response in DataSource page
pyRawMessage = "Equipment MT1421TPK481 successfully removed"
The out of box connector rule throws an JsonMappingException
Can not instantiate value of type [map type; class java.util.LinkedHashMap, [simple type, class java.lang.Object] -> [simple type, class java.lang.Object]]
from String value ('Equipment ERT1231 successfully removed'); no single-String constructor/factory method
I tried changing the property type of the property mentioned in the Response to PageList, Page, String, Java Object, Java object List.... but all threw different type of exception. Please can you throw some light - if there is any limitation with Rest JSON etc..
Is there any solution you could suggest? thanks very much for your help.
