Paid Media(Google Ads) Destination Clarification
We tried to add a Google Ads test account and tested the synchronization, everything worked as expected in the development environment. The actual Google account also needs to be added in the same way in production. But The Google API Team is asking the following questions. Could anyone please comment on this?
1) Do you have the ability to modify the code base that interacts with the API when using your developer token with [https://www.pega.com/]?
2) Do you have access to the server that is running the code when you use your developer token with [https://www.pega.com/]?
