Coforge DPA
OpenSpan CRM Training
I have installed OPenSpan but the CRM Training exe file is missing. Can anyone share the CRMTraining.exe.
Ai4Process
it is not installing during the installation process.
In your programme files / openspan, you should be able to search for and find the CRM.exe file.
Then double click in order to install it.
Then it will work.
Damien
CompTech
I found it here: Program Files (x86)\OpenSpan\OpenSpan Studio for Microsoft Visual Studio 2015\Extras\CRM Setup.msi. This is not at all obvious and should be clarified in the instructions.
VirtusaPolaris
Reallly Thanks Scott !! I found at the same the path i.e on C:\Program Files (x86)\OpenSpan\OpenSpan Studio for Microsoft Visual Studio 2015\Extras
Luxoft
Thanks Scott!
Adeptview B.V.
Thanks Scott and Damien
Accenture Services PVT Ltd
Thanks a lot Damien, but I cannot open the CRM application since I do not know the login credentials. Moreover I need the same creds for starting an Interrogation.
Capgemini BV
I am facing the same issue. Could you solve this issue? if yes, how?
NA
Just browse for that location and you will find CRM setup. Install it and your problem solved.
Tata Consultancy Services Ltd
I don't find extras folder even .Is there any alternate way?
Deloitte Canada
I also don`t have extras folder
Eclantiqx
Thanks Damien
Student Development & Student
yes, even i dont .
how to get ther crm.exe?
Zhenyu Wang Jonathan Bailey Brodie Kelley Rory Denno
