Object Reference getting destroyed in loop
Receiving this error message in the middle of a loop. The instance count is still set before it gets back to the start of the loop.
._SmartKey%WinHllapiAdapter-8CF1B70C9B01A7C\PartialScreen-8CF22671F547EA2%Index%Value Value: 17
Error | 10:25:18.029 AM | 11 | STA | Exception | | | Exception has been thrown by the target of an invocation., Verbose Message: General Information
Diagnostic Info:
Diagnostic.FullName: OpenSpan, Version= Proprietary information hidden, Culture=neutral, PublicKeyToken=f5db91edc02d8c5e
Diagnostic.AppDomainName: OpenSpan.Runtime.exe
Diagnostic.ApplicationName: OpenSpan.Runtime
Exception Information
Diagnostic Info:
1) Exception Information
Exception Type: System.Reflection.TargetInvocationException
Message: "Exception has been thrown by the target of an invocation."
Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items
TargetSite: System.Object InvokeMethod(System.Object, System.Object[], System.Signature, Boolean)
HelpLink: NULL
Source: "mscorlib"
HResult: -2146232828
StackTrace Information
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at OpenSpan.Utils.SafeInvokeHelper.Invoke(Object baseInstance, Object instance, MethodInfo methodInfo, Object[] args)
at OpenSpan.Automation.EventLink.Execute(Object sender, ExecutionEventArgs e)
2) Exception Information
Exception Type: System.NullReferenceException
Message: "Object reference not set to an instance of an object."
TargetSite: System.String get_Key()
HelpLink: NULL
Source: "OpenSpan.Adapters"
HResult: -2147467261
at OpenSpan.Adapters.MatchControl.get_Key()
at OpenSpan.Adapters.Text.Automation.PartialScreen.GetKeyInstance(String keyName, Object key)
at OpenSpan.Automation.ConnectableHost.UpdateKeyContainer(ConnectableHost connectableHost, ExecutionEventArgs executionArgs)
at OpenSpan.Automation.ConnectableWorker.DoWork(Object sender, ExecutionEventArgs executionArgs)
