Amazon
Last activity: 4 Aug 2018 1:06 EDT
Obj Methods return properties in lower case - PostgreSQL
When PEGA is used with Oracle-RDS, all Obj methods return UPPERCASE properties, but when used with PostgreSQL it returns lowercase properties. This is causing an issue when migrating applications across Databases. Is there a DSS or configuration to ensure SQL generated by PEGA when interacting with DB can be defaulted to UPPER / lower case?
You can try writing the query by overriding the column name as follows:
select Name as "name" from demo.
with this you will be able to standardized the column names regardless of any database.
Amazon
Hi
I am looking for a solution which does not involve me re-writing all the code. Is there no way to configure the OOTB Obj- methods ?
Regards
Saurabh
NCS
SG
Hi Saurabh,
better you use function as toUpperCase - if you want all in upper or use toLower - if in lower case
Regards
Bhargav
You can also check from DB side if this can be handled from there.
JPMorgan Chase & Company
Could you please let us know what is the issue you are facing while migrating, I hope the databases accept queries in case insensitive.
Amazon
Hi Sudhakar
It seems postgres defaults to lowercase and Oracle to UPPERCASE for all queries.
I am specifically looking for a scenario of Obj-Browse where i want to fetch all columns of a table and have not added the property names individually in the select clause of the method.
If I select the properties individually the mapping is perfect.
But if I do not, the query looks something like - select column_1 as "column_1".... when connected to Postgres, whereas in Oracle this would be - SELECT COLUMN_1 AS "COLUMN_1".....
Usually we need to give the property names to get column names instead of alias names.
Capgemini Sverige AB
SE
Hi, Facing Same issue. But having columns in upper case in obj-open method after RHEL migration. What is the resolution for this
Adaps
It completely depends upon the way you define the columns like COLUMN AS COLUMN
SE
Could you please elaborate where should we define this. From Pega we have external mapping of properties which is already there.No issue with Obj-Browse but at the time of obj-open/Obj-Open_by Handle we are facing this upper case columns issue.
