BlueRose Technologies
Last activity: 21 Dec 2016 5:38 EST
Not able to submit hyperlink in Rich Text Editor
I want to attach a hyperlink in Rich Text Editor. I am not able submit the hyperlink pop-up in Rich Text Editor? PFA doc for details.
Can somebody help me on this?
Thanks in advance.
***Updated by moderator: Lochan to add SR details***
Hello!
Upon reviewing the corresponding SR, we see that it has been resolved. SA-31533 was created as a result of the investigation. Please reference that if you have the same question.
Lochan | Community Moderator | Pegasystems Inc.
Hi Giridhar,
I believe you selected the text and configured the link. I tested the scenario in my local and able to get the link enabled. Tested in 7.2.1.
It seems you are doing it inside a Grid Row, is it specific to Grid ? Can you test this outside of the grid. Check for any JS exceptions.
Hi Shashidhar_Palle,
Yes. In my case, the Rich Text Editor is specific to Grid row context. On click of 'OK', I see the below JS exception. However, this is working fine outside the grid.
Can anyone help me on the above issue? Thanks in advance.
Hi Giridhar,
Even I'm able to observe this issue.
When searched, this looks to be an issue with CKEditor. To confirm the same, raise an SR with GCS.
https://dev.ckeditor.com/ticket/9005
Hi Giridhar,
Let us know if you do log an SR for this and its ID. That way we can track it and follow-up this discussion with the resolution.
Yes. I have raised an SR number. The SR ID is SR-B8469
Thanks Giridhar!
I have updated your original post above to reflect this information!
Lochan
Cognizant
I am facing the same issue in Pega 7.1.6.
Can you please let me know the solution provided by the team.
Jill
Hello!
