Need to reduce font size of reports
I need to reduce the font size of reports only. I can able to control List view font size. But report is not working. I am using Pega 6.2
Do you want to adjust the font size in the generated PDF?
No Gayathri.. I want to reduce the font size of Report , also it should not impact any other screens.
Can you please look into this.
https://community.pega.com/support/support-articles/htmltopdf-generates-very-small-fonts-output-pdf
Hi Suganya,
Can you please look into these:
https://collaborate.pega.com/question/how-control-font-display-size-rd-export-pdf
Hope this helps!!
Spandana.
Thanks for ur replies. But I want to reduce the font size of reports, Not the generated PDF or Excel.
In skin rule, we have four styles- Desktop, Work, Report,Rule.
Whatever the changes I am doing in Report CSS is not reflecting. It is working as per Work CSS. I can able to control List view font size . But not in the report definition.
Please help
I could find the CSS rule - reports_pzdeveloper / reports_pzdeveloper_rtl/ reports_enduser62 which is used to set the CSS for the report. Since it is an available rule you can make changes accordingly.
You can inspect the report and you can see the font-size where it is set and can modify these CSS rules accordingly.
Please let me know in case you need any clarifications.
Rachit
