NBA Designer V2 upgrade issue
Appreciate if someone could help on this.
I got a vanilla installation of Pega 8.6, Pega CDH 8.6 and wanted to do explore the capabilities with a sample application did the following.
Created a new CDH application pointing to OOTB PegaMKT-Data-Customer class.
Then went ahead with configuring the Taxonomy, created some issue some groups, added offers, configured the action flows, contact policy, some eligibility rule, basic channels to test and scheduled the batch.
Batch ran and I could see the offers I expected and also returning for the inbound channel via postman.
After couple of runs and tests introduced a new customer class and changed the context of the application and saved. The context was saved file without any errors.
After saving the context, the NBA Designer screen came up with a note to upgrade NBA Designer version.
After logout-login, saw the upgrade now button on the NBA designer screen and clicked on it.
It took some time and later failed.
Tried again and it failed at the same step with the below Error log
Caused by: com.pega.platform.executor.jobscheduler.scheduler.JobExecutionException: Unable to execute the Activity
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.execute(ActivityProcessor.java:65) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.run(ActivityProcessor.java:110) ~[pega-executor.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1380) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1123) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1004) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImplForModules.doWithRequestorLocked(PRSessionProviderImplForModules.java:83) ~[prprivate-session.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.run(ActivityProcessor.java:101) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.JobSchedulerProcessor.execute(JobSchedulerProcessor.java:110) ~[pega-executor.jar:?]
... 13 more
Caused by: com.pega.pegarules.pub.context.InvalidConfigurationException: No such Access Group: POC:Administrators for thread STANDARD
at com.pega.pegarules.session.internal.authorization.context.GlobalContextCache.getBasicApplicationContext(GlobalContextCache.java:438) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.authorization.context.GlobalContextCache.getLocalizedApplicationContext(GlobalContextCache.java:449) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.authorization.context.AuthorizationContextManagerImpl.getContext(AuthorizationContextManagerImpl.java:120) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.authorization.SessionAuthorization.getContext(SessionAuthorization.java:485) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.authorization.SessionAuthorization.getContext(SessionAuthorization.java:429) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.authorization.SessionAuthorization.setAvailableAccessGroups(SessionAuthorization.java:523) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.authorization.Authorization.setAvailableAccessGroups(Authorization.java:758) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.authorization.Authorization.setAvailableAccessGroups(Authorization.java:750) ~[prprivate-session.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityExecutor.setContextToAccessGroup(ActivityExecutor.java:77) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityExecutor.switchContext(ActivityExecutor.java:69) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityExecutor.executeActivity(ActivityExecutor.java:48) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.executeActivity(ActivityProcessor.java:73) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.ActivityProcessor.execute(ActivityProcessor.java:59) ~[pega-executor.jar:?]
... 13 more
Verified that my operator has Admin role and HasPrivilegeToManage when rule also returned true.
Why does the upgrade process fail after 75% if it is because of Access Group issue?
The upgrade option showed up only after we changed the context to our custom customer class. Is this expected?
