Last activity: 16 Aug 2018 8:58 EDT
Missing rules / Wrong Prefix on SubCases / Unwanted application shift on the fly...
We have a bit complicated problem as we have been facing with it for several months with a relatively low occurrence.
The problem become visible when our sub-cases (those are triggered from top case) take "C-" prefixes instead of the defined ones on case designer.
We have searched the logs and checked the clipboard of the case with "C-" prefix.
It seems that the application switches from our application(ImportLCFW) to the other one (FTCollectionsImport). The operator has access groups of both applications on the profile.
As a result of this, we believe that the system cannot take proper prefix from the application.
In addition to that at the system cannot find some rules those are expected to be executed by rule resolution. The rule in the expected Ruleset and the ruleset is defined in the application. As this problem occurs time to time and probably has no pattern, I think we can not find any issue on application stack.
I have attached the error in tracer about the rule which cannot be found in the application.
Any help & support appreciated.
Thank you
