NJ Courts
Last activity: 28 Aug 2017 15:12 EDT
Missing Properties on BIX
Hello All,
I am trying to create a BIX Extract on some of the properties from the work class but I don't see all the available properties.
Any reason why Pega would not display all the properties.
Pradeep
Wipro Ltd
Can you share the screenshots of your extract rule? What is the PRPC Version? What kind of property is the base property?
NJ Courts
Thanks for the reply @baigh here are the details:
screenshots of your extract rule? Attached
What is the PRPC Version? 7.1.8
What kind of property is the base property: String
I don't see any obvious reason why those properties would not be in the list of properties to add to the extract. For a sample WO that has these properties set can you open the instance and show the clipboard.
J.P. Morgan Services India PVT Ltd
Are you expecting the property in "PropertyNameContains" text Input?
NJ Courts
This has been identified as an issue with Rule Resolution Caches, all the missing properties were in 01-02 Version and rule resolution , Pega supplied a hot fix.
Hi Pradeep,
So glad to hear you received a hotfix for this. Could you please comment with your SR ID so that we can properly track this?
Thanks!
NJ Courts
SR-B43868
Thanks Pradeep!
Upon reviewing your associated SR, I see that SA-39577 Missing properties in BIX Extract property configuration was generated as a resolution. If you are having the same question, please review this SA.
