KDDI Agile Development Center Corporation
JP
Last activity: 7 Aug 2023 10:33 EDT
Is Migrate-script required to clone a system for updates?
We are planning to upgrade Pega ( from 8.1.8 to 8.7.3).
We plan to upgrade in-place because we can have a sufficiently long downtime during the upgrade.
On the other hand, we would like to apply the update to CLONED-DB that is clone of original(8.1.8) so that we can return to the original environment if a problem occurs.
To clone original DB, we would like to confirm whether we need to use the Migrate script provided by Pega or whether we can use the DB backup and restore method provided by the DB vendor.
Also, if we need to use the Migrate script, we would like to clarify its configuration properties.
The attached file is a slide outlining the update we are currently planning, and this query relates to the 4th step,"clone DB".
