Knowledge Expert
FR
Last activity: 10 Nov 2020 14:00 EST
Mapping JSON in Service-REST (DateTime, pxObjClass, Numbers)
Hello, is there any way to map response for Service-REST to JSON with correct data types, but without pxObjClass?
Current behaviour for Service-REST:
Situation 1:
Map from: JSON, Use fast processing: No, Map from key: .response_GET
Result: pxObjClass is absent in the reponse (good), Pega DateTime properties were not converted to ISO format (bad)
Situation 2:
Map from: JSON, Use fast processing: Yes, Map from key: .response_GET
Result: pxObjClass is in the reponse (bad), Pega DateTime properties was converted to ISO format (good)
Please don't propose any sollutions including replace by regexp or using any other functions converting a clipboard page to JSON string line. I need working Map from: JSON sollution.
***Edited by Moderator Kayla to update Platform Capability tags****
